SX-m 1.6 Outdrive
hightide185
I bought a used 2005 Kayot and the outdrive I shot, nothing but water from the lower unit plug. Anyone know a good source for a new outdrive?
I need SX-M 1.60 outdrive
sdmnglastron189
I just replaced mine on my SX-M 1.97
Gimble Bearing for this is Sierra 18-2100, It is the greasable bearing. http://www.iboats.com/Volvo-Penta-G...2778931--session_id.977235562--view_id.269488
I also ordered and replaced the Seal that is in front of the gimble bearing, but it is a MOFO to get out just to let you know.
http://www.iboats.com/Oil-Seal-Sierra/dm/cart_id.392778931--session_id.977235562--view_id.222058
Ordered all parts here on iboats.com very fast shipping.
Replace bellows with OEM Volvo Part # 3841481- I have heard to use the OEM Bellows versus the aftermarket ones, just what I've heard?
Also replace the oblong water intake seal 3852560 when you pull off your drive.
Drive shaft Orings 2 ea-Volvo Part# 3852565 or Sierra Part #18-7153
You will need a 3 jaw puller to get the bearing out and an Alignment tool as well to make sure you line up the engine with the Gimble bearing once installed. If you search in the Sticky's in the Volvo penta area it shows you the specs for both tools.
sdmnglastron189
Sorry for some reason this was posted for your question but should have been posted for another guys question?
