SX-M outdrive Oil Plug issues
Wanna Tango
Hi All,
I have a 2000 2600 Seaswirl Stryper with a Volvo-penta 5.7 gsi and a SX-M outdrive. Trying to change the drive lubricant and I am unable to remove the oil drain plug.
I tried Freeze-off and PB Blaster but was unsuccessful. Any tips or tricks on removing this? Should I try to use a torch to heat it up? Worried about warping or something to the drive.
Any help will be great! TIA
Horigan
Someone here suggested replacing that plug with one that has a Allen fitting, which I bought. Looks way better than the original.
Google - Drain Plug, Magnetic, Johnson, Evinrude E-Tech
