sx-m outdrive squeaks when turning
rs1lollie
my 1998 sx-m outdrive squeaks when turning the wheel or grabbing out drive and turn it, engine is not running. is there anything that i need to grease of spray lube... the only zerk on out drive is for gimbel bearing...
Augoose
There are several components at play here - try to narrow down the source of the squeak and see where it is coming from to further troubleshoot.
rs1lollie
its coming from what i do believe is the side to side pivot point on the out drive, sounds like a squeaky hinge
