SX-M Volvo Outdrive loud vibration when put in gear
J.D
Someone used my boat without authorization. I'm sure it was my ex after we broke up. Must have gotten stuck in shallow water. Tore aluminum prop up. Now there is a loud vibration coming from outdrive when put into gear. Any ideas on what it could be? and appx what kind of money I should expect to spend to have it repaired? 305 inboard engine still runs and sounds great. Learned a valuble lesson. Lock up your boat when it is in a marina, don't count on marina to notify you of anyone using your boat...
skydiveD30571
Re: SX-M Volvo Outdrive loud vibration when put in gear
Did you replace or repair the damaged prop? What prop is on it now? If you tried a new prop and still get the loud vibration, you can bet on a bent prop shaft, if not other gear damage as well.
