My boat is a Glastron SX175 witha 3.0L Volvo engine and an SX sterndrive (2004).
I have pulled the drive to grease the bearing and check the ujoints, everything is silky smooth (35hours from new). I want some help with checking the alignment, It has not been done before and i dont want to create a problem, currently every thing with the engine and drive is fine, but having read a few post alignment looks like it should be checked every year -
I have my alignment bar, but before i start i wanted to understand the correct proceedure, i have check the volvo drive manual, and it just says the bar should slide in and out smoothly. If it does not, which mounts should i start adjusting and by how much, the engine has two mounts front and back each one has a large nut on the top which i assume needs to be slackened.
UKBoater
UKBoater
