I have a 2005 Stingray with a 5.0 GL-E and I am having a issue with the tilt/trim motor. long story short it all together stopped working on the lake, I got the boat home and found the plug got hot and had no power to the motor. I replaced the pump and now when you tilt it up it makes a bad squealing noise. the oil level is good with no leaks any suggestions would be great thanks
