Re: Sx to dps ratio`s
Walt, if you are running "C" props, you have an AQ series drive (main suspension fork & pivot tube geometry)
The OP is asking about a DP-S (gimbal system) drive.
I agree, the ratio will be very similar if not the same.
BRICH, *short of an extremely lightweight and nimble hull, your engine will determine the final and overall drive ratio.
If this is a very typical 24 footer, the 1.95:1 is going to be correct for a 5.7L engine.
You will need to test an array of propeller sets, and perform your WOT RPM testing just as you would with your single prop drive.
