2001 yamaha sx250txrz I have cleaned o2 sensor changed the three fuel pumps cleaned the vst filter the fuel pump filter,I just pulled the fuel injector filters out and cleaned them,they were clean,I replaced the plugs also checked tps voltage and adjusted the butterflys per service manual..It surges around 1800 ,It wont stay at a set rpm between 1800 and around 2800 rpm.set it on around 2100 or so and it zooms up to 3300.... ...any help would be appreciated
