Ok so i tried to do the sync and link today but in the process of getting the cam to line up and the carbs to open up fully of which neither was happening which is why i thought to do this. I ran into this problem for me to have the carbs open up all the way at wot the cam doesnt line up at all i havent tried to start the engine yet since the cam isnt lined up. The roller is just barely touching the cam in the setting it is in now. I cant get the tie bar to adjust far enough to open the butterflys all the way there is just not enough threads on it. I took this picture in hopes of someone telling me if it is the right cam or not. The cam has a mark on it you can clearly see and then it has one on it that looks like someone had put on there with a screw driver and the rolller is in between the two right now in this picture. I am unsure where or what to do next since i dontknow if this is the right cam and tie bar. One other thing i know i need to fix is the ball sockets are cracked and if you tighten the back up nut to much then bar comes out due to the crack opening. I noticed this today as i was finishing. What i could do.
