Re: synthetic oil and 1:24 mix engines.
can't carry the technical discussion re. bearings much further. It's my understanding, though, that there was a significant change beginning with the '57 model year. Again, I'm open to correction, but I think that the bearings used beginning in '57 were essentially the same as those in contemporary use. I thought that babbit bearings were the outmoded variety, but maybe my terminology is wrong. Synthetic vs. non-synthetic, of course, is a separate issue -- but the engineering change, if my sketchy history is right, may mean that pre-'57 motors are more subject to failure if the oil mix is too light.<br /><br />Actually, the information you received re. babbit bearings probably implies that those bearings are the contemporary variety, and that (perhaps)needle bearings were discontinued after '56 (?)
