For what it is worth, this is from the 2004-1 hard copy issue of "DIY Boat Owner - The Marine Maintenance Magazine" Page 15 (WWW.diy-boat.com)<br /><br />I am going to paraphrase the Q&A<br /><br />A guy with a 1992 Merc 5.7L with a Bravo II writes in asking about using Synthetics. DIY responds:<br /><br />"In Oct 1997 Merc issued a service bulletin. The recommended oil for your engine is Merc or Quicksilver 25w40 marine engine oil, It is a blend of straight 25 and straight 40 designed for marine use. If that is not readily available a high quality SAE 30W detergent Auto oil with an API service rating SH, CF/CCF-2 can be used. The use of non-detergent oils, multi-viscosity oils, synthetic oils, low quality oils or oils with solid additives is specifically not recommended."<br /><br />Like I said, for what it is worth. DIY does note that they have not seen any failures from using synthetics but they recommend sticking with the 25w40. I wouldn't expect them to contradict Merc given the potential liability...
