Synthetic oils in outboards - Can I use them?
bairwin
I have a 25hp & 3.3hp Mercury outboard. I would like to start using synthetic oil in them (gas & lower unit). We use alot of synthetics in critical industrial equipment where I work & the plant engineers swear they offer far superior lubrication properties (higher film strength etc?). Does this same arguement hold true for outboard synthetic oils? If so can you recommend some good brands to use. Thank you.
Black Max
Re: Synthetic oils in outboards - Can I use them?
I have been using synthetics for a while now with no problems.<br />THe best synthetic that I have used is Amsoil.
D
DJ
Guest
Irg,<br /><br />Yes you can use them. I believe Mercury offers their own. That's the one I would use.
Mod2
Wizeazz is outta here.
bubbakat
thanks mod 2 and ditto to the other guys replies except the other one mod 2 lowered the hammer on
n0ukf
moderator1, when you move a topic, is the original poster (or all replying posters) notified that it was moved?
