I have a couple of questions about this:
The tach on this boat does not work - pointer never budges. However:
Should I assume the tach is bad? Faria site says they will repair for $60, and that's fine but I want to be sure the tach is bad before I send it to them.
Second question, the alarm (beep) on the system check works but very faintly - no chance it would be heard if the boat was running at anything beyond idle. Is this correct or should it be louder? Is this horn the red device under the dash about 1.25" in dia.?
The boat is a 16' Stratos 170FS, 2005, with the 2005 115HP Johnson J115plsor. We got it very slightly used and are happy with it so far.
Thanks to anyone who can answer,
gbw
- The System Check lights in the tach flash in sequence as they should and the beep sounds, but very softly, so I assume it's working correctly - at least I hope so.
- The charging system shows 14.4v to the batt. terms at just over idle speed so it's charging (12.78v turned off) so can I assume the rectifier/regulator is working right?
gbw
