System check not working on brand new Evinrude
jogge_w
I have just installed my brand new Evinrude Ram Ficht 90 hp. The engine is running but the system check does not work. Is there something that I have to reset or what can be the problem?<br /><br />BR Jörgen
seahorse5
Re: System check not working on brand new Evinrude
Does the system check go thru its beep and turning the warning lites on and off after you turn the key to ON?<br /><br />Are you using a System Check tach or the 2" gauge?
DHPMARINE
Also what year is this Ficht?<br />DHP
jogge_w
I´m using the System Check tach and the doesn´t beep or turn on the lights when turning th igniton on.<br /><br />Themodel year is 2003
seahorse5
All the electronics are inside the tach. If it doesn't work, then the wiring connection is not fully seated (use dialectric grease), the wiring is bad, broken or incorrect, or the tach itself is bad.<br /><br />do the rest of the gauges work OK when the key in ON?
seahorse5
system check gauge wiring<br /><br /> here's the pin configuration (looking at the back-side of the gauge, holding it upright):<br /><br />1-2-3-4<br />8-7-6-5<br /><br />Purple wire goes to pin 1 - 12V positive<br />Black wire goes to pin 2 - ground (earth)<br />Gray wire goes to pin 3 - tach signal<br /><br />Grounding these pins, will activate the following:<br /><br />Pin 4, turn on no oil lite<br />Pin 5, turn on low oil lite<br />Pin 7, turn on check engine lite<br />Pin 6, turn on hot lite<br /><br />Pin 8, is used to activate the warning horn, it supplies a ground to the horn circuit when any other warning circuit (pins 4 thru 7) is grounded
jogge_w
Thank you for your rapid answers mr Seahorse.<br /><br />One more question: The tach is possible to set at 5 or 6 pulses. Which is right for my engine?
DHPMARINE
Does this system still require a horn,adapter,or both?<br />DHP
ob
Set tach to position 6.
