System check tach issue
Lowedeck
I am waiting on a DVA adapter to test the stator and regulator rectifier to see as why my tach is not working correctly, but doing a little tinkering today and found that the grey tach wire and the black wire have 3382 ohms with no continuity between them when connected to the system check tach would this be an issue or an I looking too hard into the issue? I am checking this back at the the power head all the way from the tach Its self. With the tach not connected I get no resistance at all.
Second issue: when engine is turned on the system check tach beeps doesn’t the light up of all of the system check lights and they go away. When shorting temp sensor, deleted oil level switch and vro pump all of the lights come on but no horn sounding. Any ideas?
Joe Reeves
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
NOTE: For the later models that DO NOT incorporate a wiring terminal strip, splicing into the "Yellow Wire" mentioned will be necessary.
Normally the Gray wire leading from the tachometer is attached at the terminal strip to another Gray wire which leads from the water cooled voltage regulator/rectifier...... remove the gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences.
Lowedeck
i have found this on other links and have tried the test above I have a 1996 johnson j115eledr I have tried to jump the yellow grey to the grey wire directly with no tach movement still and have an extra faria tach that I have bought and also tried to test. So I am still waiting for the dva meter to check other issues but it still is weird I don’t get anything when jumping yellow grey directly to grey tach wire on eithier tach.
Also so I don’t know if their should be any testable between the grey and black when connected to the tach?
