System Check Tachometer
ddiebel
When the key is in the on position and the motor is not running, my tach does not read zero and seems to randomly jump around. When the motor is running the tach is not accurate. Prior to this weekend it worked fine. Any ideas on what I can check>
Barnacle_Bill
Re: System Check Tachometer
Check all your conections. If they are good replace the tach.
