T&T for 75 Johnson 115
billyt
Seems like a daily deal of something going haywire--guess it will take a while to work all the bugs out. My trim unit for my motor was working fine, but now the trim motor kicks in to lower the engine, but when I hit "up" all I get is a "clunk" in the box where all the wiring is. It's like something is making contact, but not activating the motor. Any clues? I did see where one contact looks a bit corroded and I'll clean that off. Other than that, what should I look for? blt
OBJ
Re: T&T for 75 Johnson 115
BLT....if your "box" is equipped with only one solenoid, this is used for raising the engine. Jump the two large posts on the solenoid with a suitable jumper. If the engine raises, replace the solenoid.
