I can't see a trim sender on the motor all I can see if limit switch on the transom bracket. Where should the other end of these wires end up ??
EDIT:
I see that those two wires are connected up to the 2 blue white ones from the limit switch.
i'll install a sender and hook them up to that so that should work the trim gauge
where do the 2 blue and white from the trim limit switch connect to then ???
