T9.9 won't start
bad1129
My Yamaha electric start T9.9EXHC won't start. The battery is fully charged but the starter does not engage nor does it even click. Beside the obvious loose battery connection any suggestions on what else to check? Can I jump the starter button to see if that will start it?
I never had any luck using the backup manual pull starter.
99yam40
also a bad switch, bad relay, bad starter,or bad wiring/connection
