tac and gas guage problems
jeff6898
79 85hp evinrude 85999R
Replaced ingnition switched yesterday. Before I did that gas guage did not work and tac worked great. Now the gas guage works and the tac stays pegged out at full. Seems there is a purple wire connected to the switch that when I play with it makes the gas guage needle jump. Does this purple wire have anything to do with the tac and gas guage?
rickdb1boat
Re: tac and gas guage problems
Yes, the purple wire is the ignition (12 volts) wire. It would hook into the the fuel gauge "I" terminal as well as the Tachometers "I" terminal. Look for a bad or corroded connection at the gauges.
