Tach and Rectifier question
kax2000
1969 EVINRUDE 55 HP
I replaced original amp with new CDI amp that has no tach support. They say to connect tach wire to yellow stator wire.
I have NOS tach that supports 12p and it does not move the needle when running.
Tested rectifier and showed bad.
The question is if I disconnect the rectifier will the tach still function(for testing), or do I need a functioning rectifier to have the tach read correctly?
Re: Tach and Rectifier question
The tachometer is driven by the charging system and not the ignition system.---So yes the rectifier needs to be in the circuit,
boobie
Connect the gray tach wire to one of the yellow stator wires once and see what happens.
