Tach connection for '73 9.8hp
60sboater
It's tiller operation. Can a tach go to the negative terminal (input from stator) of # 1's ignition coil? Phasemaker
flyingscott
Get a tiny tach or something similar that gets it's signal from the spark plug wire. The problem with those coils is they tend to break the posts loose if you mess with the nuts after this long. And considering the price of the correct coil a tiny tach is cheap.
60sboater
I have a Tiny Tach and I didn't think of a 2-cyl not working with a conventional tach. Thanks.
