tach hookup problem
tschamp20
im trying to hookup my new teleflex tach.inst. say to hook send terminal to (I) on ignition switch or green wire. i do not have (I) terminal or green wire. which switch terminal do i hook it to? i have B,M,S,C,A,M!THANK YOU!
rickdb1boat
Re: tach hookup problem
Send terminal goes to gray wire. "I" goes to purple ignition wire.
F_R
That would be the "A" terminal on the switch. It is the 12volt supply with the switch turned on.
tschamp20
ive got inst. in pdf form and now i see where i was reading wrong.thanks rick.your referring to solid purple correct?
F_R
Re-reading the question, the sender wire goes to grey tachometer feed as previously stated. The 12v supply wire goes to the A terminal.
tschamp20
excellent!thanks for roming the bb.i was going delirious over here.
