Re: tach install 2002 90 Yamaha
I received the tach kit. My control box is a 704. The only leads I can find coming from the control box are three leads, two male (green and red) and one female (black). These correspond to the three wires on one end of the tach harness. Are these the right wires? If so, since the red wire on the control side is constant and the yellow on the harness is switch power, do I need to wire the yellow into the switch? On the tach end of the harness are female green, yellow, blue, and black. These all correspond to the leads coming out of the tach. This leaves a male black on the harness with no corresponding connection. Where does this go? Also, where do the double yellow and blue that are about a foot up the harness connect? Do these connect to the nav lights, yellow being power, blue being... ?<br /><br />On the trim harness, they seemed pretty self-explanatory. The one with the green/red stripe and green/white stripe. The harness side has the two green wire plus two others (one is white/red and the other is blue/white) but the plug on the engine side only has the two green. Is this right? The other plug on the harness side has grey, black/white, pink, and orange. The plug on the engine side does not have the orange. Is this right?
