Tach is too high
cooter2506
I have a 5.0 Mercruiser 1998 and my idle is set for 700rpm but my tach reads 1300. tach moves when you give it throttle but I want to replace the tach. I picked up a tach but it said ot to use it on Thunderbolt ignition. Any one knoe of a good tach that I can use.
ricksrster
Re: Tach is too high
There are many at the iboats.com Marine Store.
On the back of the tach you have now make sure the little switch is set to the proper setting for the number of cylinders of your engine.
