Tach issue
benthooks
I have a 1995 3.0l outboard with no tach responce the tach zeros with keyon-engine off and getting about 12.5-14 volts on sender wire the Tach is made by faira and i have the setting for pole set to 6p. What is the best way to tell that the tach is good and any suggestions on the tach issue.
benthooks
Re: Tach issue
No this is a diff motor worked fine last season with other motor.
verado7
Re: Tach issue
your new motor is a 12 pole not 6
if your tach reads up 7000 rpm use setting 5
if it reads to 6000 rpm use setting 4
benthooks
Re: Tach issue
I tried 5p matter of fact i tried all settings could this hurt the tach.
Also what type of voltage should I be getting from my Signal wire the grey one.
hkeiner
Re: Tach issue
Have you read the troubleshooting guide linked above? Your question is answered in there.
benthooks
Re: Tach issue
I have tested it With ACV and at idle i get between 8-10volts AC on the signal wire the trouble shooter only shows a min of 5 VAC at idle what the limits of signal Voltage
