The motor is a 1998 Mecury The tach works at sporaticly at different rpms of the engine, never the same, the voltage output on the battery charge gauge reads 12v at idle then up to 18v when running at average speed I have to estimate at about 4300 rpm. are these two related and what may be the cause? the motor appears to be running fine.<br />Thank you for your help
