Re: tach problem
Rick , thanks for the reply, work has been so busy that i have not had a chance to check out the voltage untill now. The voltage started at 12.5 and slowly worked up to 13.68 to 13.70 and stayed there. Whats odd is that while the engine is cranking, the tach reads the rpm untill it starts and then it drops to 0. If i pull out the overboard switch so the engine will not start while i crank it over, the tach shows the corresponding rpm? For some reason when the engine fires up the signal to the tach is lost. I'm going to trace the signal wire at the tach down the line to see if i can find a loose connection. <br /><br />thanks
