Tach problems
xlav8r
MY TACH IS ACTING FUNNY . IT DOES'T LOOK LIKE IT IS RESPONDING CORRECTLY. THE NEEDLE LOOSELY RESEMBLES THE TRUE READING. WHAT SHOULD i BE LOOKING FOR AS A SOURCE OF THE PROBLEM
boat127
Re: Tach problems
check tach setting on back of tach my have corrosion
check the connections at back of gauge
check the engine/boat plug barrel connection look for corrosion there in the pins
check the gray wire on tach
your problem is probably a faulty tach
