Tach Question 1978 35hp Jonny
riverjet502
I would like to wire a tach onto my 1978 35hp Jonny. It has electric start but doesn't have charging capability. Is it possible to adapt a tach onto this or is my only option a mini tach with a wire wrapped around the number one plug wire? Thanks..
F_R
Re: Tach Question 1978 35hp Jonny
Something is wrong here. A 1978 should have battery charging. Are you sure it is a 1978? Or, did somebody add a starter to a rope start motor? Whatever, if no charging alternator, your option is an inductive (plug wire) tach.
riverjet502
Yes it is a 1978 model. I did add electric start as this was a factory rope start when new hence no charging capability. How tuff would it be to add the alternator? Is a mini tach my only option at this point? If so which model am I needing to get? How accurate are they? Thanks
