Tach question
zach103
Is there any way that a tach for an inboard engine can be switched to perform correctly with an outboard? i have a bunch of gauges from an inboard that i would like to use
cheesegrits
Re: Tach question
Yes, if you go to the johnson like you were talking about most of them have a setting for a 12 pole. They look like this on the back.
This is the back of a Faria one I got. All I have to do is set it to the #4 position
This is the back of a OMC one.
izoomie
Re: Tach question
Cheesegrits, do you want to sell the OMC?
Silvertip
Re: Tach question
It all depends on the design of the tach electronics. An 8 cylinder -4 stroke produces the 4 pulses/engine revolution. An outboard engine tach does not use ignition pulses but rather uses pulses from the stator and in the case of OMC and other modern outboards, that is a 6 pulse signal from a 12 pole stator. So IF the I/O tach will recognize the OB signal AND the tach has no OB setting, you don't have much choice but to set the calibration dial to 6 cylinder and then double the tach reading. The number of cylinders an outboard has is not relevant.
seabob4
Re: Tach question
I've got a decent shape OMC (system check in the face) O/B tach if you're interested. Let me post a pic in a bit...
izoomie
Re: Tach question
Nice pic, I have a 1988 johnson 90hp. the boat has no guages now. if i get the right wire harness do you think this tach will work with my motor?
izoomie
Re: Tach question
Ok Seabob4
I think it's used, am I right?
How much do you want for it plus shipping to guelph ontario canada?
seabob4
Re: Tach question
Ok Seabob4
Yes, it's used, but works fine. PM me, I'll get back to you.
