Tach Question
JGra
Hello, I have a 96 Sunbird That I picked up. I am trying to get the gauges working. I am down to all but the tach working. I get no movement in the needle at all when the key is switched on or off. I have power to the purple wire on the back of the tach and have a good ground also going to it. What kind of power or signal should I be getting on the gray wire. I dont want to fry andything so any helpd would be great. It may just be a bad Tach but am not sure. Engine is a 1996 Evinrude 88 SPL,Thanks.
Chris1956
Re: Tach Question
The grey tach signal wire will be connected to the stator at the Voltage regulator. You should see an AC voltage on it, when the motor is running.
