Tach quit working
mikebc
I think my tack is shot, it worked 1/2 the time until yesterday, now nothing. I checked all the connections on the back of the tach, good ground, good 13.5volts, and I get a variable voltage on the gray wire, from 6 volts up, depending on my rpms. The needle just sits at 0 on the tach. Is the variable voltage normal, and if so what is the norman range? Does this sound like how a tach dies? Thanks, Mike
mikebc
Re: Tach quit working
Is it possible to test the tach some how?
nms1991
The grey wire is the signal wire for the tach. Tachs sometimes just die or they fluctuate then die but it sounds if tho as you need a new tach. Most mechanics have a shop tach to check the system with.
No Doubt About It..............
