Tachometer conversion
Farnswj
I recently retrofitted my 74 mercruiser 427 engines with marine GM high energy ignition systems. I completely gutted the Thunderbolt ignitions. The port engine tach reads approx. double the actual rpms. I havent even connected the gray tach wire on either engine so where is this signal coming from fellas ?
if you have twins, you also have an engine sync gauge
both tachs need to be connected for the "system" to read properly
Farnswj
Thanks for the info...only the port engine tach is operational...the synch is located on the flybridge, and is disconnected...any additional info would by greatly appreciated 😉
