Tachometer help
tom2
Hi,<br />Can a photo tachometer be used to measure RPM in outboards?<br />Thanks,Tom
Mark42
Re: Tachometer help
You mean a contact tach? If it can go up to 6000 it should work. But I would not want to be holding a contact tach against the flywheel nut with the boat underway screaming at 5000+ rpm! :eek: <br /><br />If you want to check the idle rpm it's probably safe. Make sure you don't have loose clothing on to catch in the flyweel teeth. Could be a disaster.
