tachometer interchangeability
Harry Blanchard
I am looking for a tachometer to check my 2 cyl and 3 cyl Yamahas out for tuneup purposes. A fellow has one that he says is for a 3 cylinder Merc, will it connect up, and how do I go about connecting it up.?
rickdb1boat
Re: tachometer interchangeability
Harry<br />It will work if it has adjustable "Pole" setting. Check the site below for info on settings and installation.<br />It's a PDF file:<br /><br /> Teleflex
Harry Blanchard
I tried clicking on the teleflex file, they sent me to adobe, from there I am lost, any help?
Trent
Sounds like you need to download the Adobe software to view the information on their site.
rons boat
Perhaps I can help. The tack in a late, since the 80s motor, all work off the stator which gets its signal from one of the two leads, usually yellow-yellow on all single phase stators. This signal is taken from either one of these leads and provides the signal to the tachometer. The lead that goes to the tach is most frequently grey and is connected to one of these yellows comming from the stator. This grey lead that winds up, after passing through the harness, goes to the remote control on the boat and gets connected there to the tach. The tach connection also gets 12V and ground from the remote control and the signal lead we have been talking about. The selector on the tach is set for 2,3,4, or 6 cyl for proper reading of the tach. Locate the grey wire at the stator connection x-conn and follow it at the control assembly. This should be easy to find and is usually very universal. In summary the stator provides a pulse each time there is a spark produced which the tach interpolates as rpm. 2 cyl fires twice per rev, 3 cyc fires three times and so on.
Harry Blanchard
Thanks a bunch, I will see if we can match up all this information.
rons boat
I must modify my color instruction after reviewing Yamaha's wiring color codes. The lead that carries the sig to the tach appears to be green on Yamahas(gray on most). The two leads comming from the stator are different as well. But if you subsititue the color codes then all is the same. To connect at the power head just locate the same cross connect, obtain power and ground, set cyl and the Mercury, Omc, tachs will work fine.
