Tachometer issue
gwhjr98
Not sure if my tach is bad... Yesterday the WOT RPM was 4400 and today it is 5000. Checked the wires etc... no change in the boat just a change in the WOT high end. Any suggestions ?
alldodge
Tach's are not that accurate, need to get a hand held to be sure
thumpar
Try tapping on the talk with you knuckle. Mine will sometimes go up to mid 5k or stick at 3k even with engine off. I tap it and it goes back to normal.
Ayuh,..... Mine took a severe beatin' the other day, before I believed it to be Anywhere near true,......
ihearth2o
+1 on tapping the tach.
I'm assuming you took the wot rpm readings with the same load, same prop (or same condition prop), relatively same conditions (wind/current/etc.), anything that would affect your drag?
gwhjr98
Ok. rapped on it.. and tightened the nuts on the back... now its reading 4000.. same top end speed.. time to get a new one.
grewvin1
Sometimes you can turn the dial on the back that is for 4-6-8 cyl, give it a crank back and forth to get rid of possible corrosion on the contact and I've found mine to settle down.
