Hello my gauges are a year old. I seem to have power going to the tach all the time. It's at 500 Rpms with the key off. When I turn the ignition on it will zero out again. It was not like this when I installed the gauges last year. I removed the purple and ground wire from the coil which didn't do anything. When I disconnect the battery negative that doesn't zero it out either.
