Tachometer question
ONEGA
There is a dial on the back of tach to set it to 4, 6 or 8 which corresponds to the number of cylinders motor it is going to be used on. I'm replacing my tach with one sitting on the shelf and the dial on the back of that Quicksilver tach offers four options which are 1, 2, 3 and 4.
Does anybody know at what number to set it for V8 motor?
Thanks.
GA_Boater
Does the Quicksilver tach have a model number on it. Sometimes you can find instructions on-line. Also some tachs work for two and four strokes, while others only work on one or the other.
grewvin1
No Title
You know your idle is 650 to 750rpm or so start eng and adj. when reads right most likely the one. I had to do the same
alldodge
Thanks.
1 = 4 cyl
2 = 6 cyl
3 = 8 cyl
4 = 12 pole outboard
