Re: tachometer settings
Whats the over heat condition?
2003 Volvo 3.0 GLP-B chaparral 180 with 49 hours bought a couple weeks ago from a trusted friend. Had been run once the last year and supposedly flushed adequately (salt water use).
Test run while on muffs saw temp while flushing go to 180 and immediately drop to 160's then steady at 175. Thermostat seemed to work fine.
Tested while underway, could not get RPM's above 2200 and speed was obviously slower than expected (because of incorrect tach settings was in reality probably in the 3000 or above range). Temp remained stable though at 178.
Changed impeller that looked brand new, and while changing plugs I found one that broke off while removing the boot. I found that I had been running on 3 cylinders. A huge difference the next time it was run with Rpm's now up to 3400 (in reality, probably at spec of around 4400).
Temp however began climbing whenever I got above 3400. Seemed steady at 180 yet up to 210 when WOT. Never let it get above that, and never let it stay there for more than a few seconds. Reduced throttle and back to 180.
Did complete tuneup-cap, rotor, plugs, pump fuel filter, inline fuel filter, drive oil, engine oil and filter, thermostat.
Checked thermostat in the kitchen and it opened and closed at specs. Thermostat housing had some less than pea sized gunk that cleaned out. Changed it anyway.
While running on flush adapter yesterday it overheated to 210 again and I gave up. The heat issue doesn't seem related to whether or not I am on plane, or related to the thermostat. I also ensure that my flushing cap is tight so as not to draw air. I am guessing that since it ran fine earlier at low rpm's without overheating, yet now even with just a flush and idle it overheats that while I was running at WOT I may have broken some gunk loose and have an obstruction somewhere.
I have tried a bit of half-assed flushing, and may give that another shot today as I haven't flushed the power steering hose. I may also have another look at the impeller housing and tighten the 4 screws more. Would no overheating with the thermostat removed tell me anything even though we know that we have a good thermostat? I can easily take it out. I have read Don's link to the overheating article and am starting to feel this is better left to the professionals. I do anesthesia for a living and try to know my limitations before causing permanent damage. I hope I haven't already done so with the 210 temp.
Anything simple you can suggest short of checking the riser and manifold or running clear hose testing?
An unrelated question: I remember that on outboards it seemed that a spin of the propeller with a finger would cause several revolutions. Should I expect this with and IO? It takes effort to spin this one.
