Tachometer stuck at 900 rpm
douglasb
Got a merc 4.3lxgen+<br />Engine was not starting when warm. Relaced coil, cap, rotor and ignition sensor to make sure. Working like a dream. New tachometer was working prior to above works. Now registers at 800 to 1000 constant even when engine off! Any ideas?<br />All wires replaced as was (I think) apart from black cable on new sensor (old one didn't have one). Connected black cable to engine block using connected ring thing.
boanut
Re: Tachometer stuck at 900 rpm
try disconecting the tach and try it may be shorted out
Laddies
Banned
Some of the new tachometers only go to 0 when the key is on--Bob
Ayuh,........... It Sounds like you Unhooked the tach while doing your repairs......
douglasb
Yeah. I will trace back and make sure all connections are good. No cables attached to coil so presume will be going back to wiring loop. Beyond there I have little idea of where signal is coming from and what alternative bits may go wrong.
