tachometer wire question
mr roach
i have posted a couple of questions about my tach got one answered and the other i figured out finally now for the next one lol. I was not getting a signal at my remote and after consultinf the seloc book i moved the brown wire from my switch box to the rectifier and am now getting a signal and tach is working and before i do the final install i just want to know if this is correct and will not cause damage or problems down the road. Thank you for all the help
Re: tachometer wire question
Ayuh,... Whatcha workin' on,..??
mr roach
you are right bond-o i brainfarted my apologies let me try again i have a 1977 mercury 115 i6 1150 with the thunderbolt ignition i moved the brown wire from the switchbox to the rectifier in order to recieve a signal to my remote control tachometer connection and want to make sure it will work properly and not damage anything or give me a false or incorrect signal. Again my apologies and as always thank you for your replies
