Tachometer wiring up
Realgun
I will be installing a tach, speed, volt, and fuel instruments in my boat. I want to turn the backlights on and off on the instruments.<br />The Volt has a + and - for the light but the tach, Fuel, speed does not. They also say they energize from the ignition switch.<br /><br />How is this wired can you help?<br /><br />Instruments are Faria Pro Red.
Laddies
Banned
Re: Tachometer wiring up
Realgun, some gauges don't have a seperate circurt for the lights if thats the case your stuck with it, some you can remove a bond strap and add another wire to and seperate the circurts and I know of one guy that went into the area where the bulbs pluged in and altered the circurt there, keep in mind that voids the warrenty---Bob
Realgun
The tach speedo and fuel have only a + for a wire can that come from a switch so I can turn the light on and off? Or will that mess up the tach function ie: turn on light and tach works turn off light tach she no work. LOL :D <br /><br /> Manual for the fuel guage.<br /> Manual for the tach.
gaugeguy
Hi Realgun,<br />From the manual links you posted, they show a lamp connection as a blade terminal. The ground connection is a stud,that will be common for the instrument circuit as well as the lamp circuit. Wire the blade terminal to the light switch and the instrument "+" to the ignition switch and you should be good to go.<br /><br />The answer to your question is no you don't want to do that as the instruments will only work when you turn the light switch on.
Laddies
Banned
Realgun, Gaugeguy is exacly right, but thats not what I am posting for, how the heck do you post the pictures I have tried but I guess I'm not smart enough to figure it out---Bob-- if you are trying to get away from night glare with the gauges put them on anoughter switch
Realgun
Let me ask this then.<br />Battery is on the guage and ignition is showing on that post.<br />So does that mean the ignition/battery mean +12V?<br />If so does that means there are 2 circuits with a common ground?<br /><br />Hopefully yes.<br /><br />I might just call Faria.<br /><br />Laddie you need to have a place that hosts the pictures first.<br /> There are lotsa free sites.<br />You will need to upload your picture(s) to that site.<br />If you can see those picture you should be able to post them here.<br />Shareaproject is cool look at my signature. then<br />Click full reply form.<br />Then you need to click IMAGE lower left column.<br />In this box you will need the address of the picture some sites have a button you need to press and it will give you the address so you can post to autions etc. Copy this address to the box. <br />I removed the pic thank you.<br />And then click add reply. I highly suggest you just post a link to the picture as it will be easier on the people with dialup to view the post.<br /> Here is the slide show view of my ongoing saga. Loads of pictures and not taking space up here.
gaugeguy
Originally posted by Realgun:<br />So does that mean the ignition/battery mean +12V?<br />If so does that means there are 2 circuits with a common ground?<br /><br />Hopefully yes.<br />
You got it
