When I got my boat (1971 Trisonic Merc888 Ford 302) I noticed the brown tach wire was not connected to the coil. I connected it to the negative post and it worked, sometimes. While cleaning the wire connections I noticed on the back of the tachometer there is a brown wire to the center post, a white wire to the light, and a red wire, which runs to a center post on one of the gas guages, which I think goes to a ground. My question is should that wire be connected to a ground or to a positive 12v wire? There has been a lot of re-wiring under the dash by previous ownwers so I don't necessary trust all of the wire colors for function (red=positive, etc.)
