Tachometer
Silvertip
Re: Tachometer
Do you think it might help to know exactly what engine this tach is monitoring?? If you have an I/O then a standard automotive tach can be used. If you have an outboard the tach must be a marine variety as they monitor pulses from the charging system and are not ignition dependent.
