Re: tachometer
The resistor should be inline with the power to the POSITIVE terminal on the coil, replacing the resistor wire that was inline. The wiring should be a straight shot from the key switch Ignition terminal thru the ballast resistor then to the positive terminal on the coil.
I know you already have a ballast resitor to wire in, but I am pretty sure you can buy the resistor wire still from a Mercruiser shop, and older 1960's or so Ford automotive ignitions used it. You could also replace the coil for one with internal resistance and just run straight wire from switch to coil. A good parts store should be able to find a universal 12v coil with internal resistance compatible with your stuff.
