Tachometer
Berkley1
So I am looking to upgrade my gauge set the one I am looking at has a tach that comes with a sending unit on my VP 5.7 the tach comes off the ignition coil grey wire can I still connect this tach to my current set up?
Ayuh,..... Hard to tell, you haven't said what this tach is,......
Berkley1
  • Engine hours: 0.0-99999.9H
  • Backlight :7 Color backlight
  • Indicating Range: 0~8000 RPM
  • Signal : Pulse
This is really the only info I have on the tach
alldodge
Would need the manufacture of the gauge
That said, a auto/marine Tach doesn't use a sender, they all use the signal coming from the coil (gray wire)
