Re: tacoma tranny swap
Yea, probably not worth it unless you could find a low milage wreck at a pick and pull which would never happen for a 2010 but chances are, 'Yota used the same manual trans+ gear for quite a few years, or at least a trans that will work... ECU MIGHT not be an issue as some brands use an identified ground pin to switch the ECU into M/T mode and shut off the TCU communication..
But for as cheap as Tacoma's can be had, just buy the M/T truck. It WILL be cheaper unless your mom partially gifts you the truck and you pay way less than book value
