Tahoe deckboat sink fuse is blowing
shassell1
Re: New 2021 Tahoe1950 deckboat
I haven’t tried the sink until today. I filled the watertank to full and toggled the switch to on. The pump starts but after 1-2 seconds the fuse is blown. I disconnected the electrical connector to the pump. I ohmed the pump side and it didnt show any reading. I also checked the connector side to power and it was reading 12v. In the fuse box, it had a 5amp fuse. If I retry it will blow the fuse. Did anyone else’s Tahoe come with a higher amp fuse? Anyone else run into this problem?
alldodge
Look at the pump it should have the amps listed on it. If not get the model number and look up the specs
Ayuh,..... Welcome Aboard,..... It sounds like both the wire from the fuel tank sender, 'n yer pump are seein' a dead short to ground, so I'd try to find someplace those wires run near each other,.....
shassell1
Hi, I checked Ns Pump is rated up to 8amp max. maybe Tahoe just installed with the wrong fuse…
alldodge
Could be, I would put a 10 amp because its easier to find
What size fuse was in it?
alldodge
If you have a switch on the sink to turn it ON like my Rinker, its just Hot and Ground. Hot is switched
