Using correct outdrive terminology? 'Stringer' ? Picked that up reading 10k posts here..
So... I'm taking on water at the launch ramp.. engine off.. outdirve up/down/left/right makes no difference.. not that I noticed anyway.
I cant really tell for sure where it's coming from other than it appears to be dripping 'down' from approximately what would be centerline. Everything's so tightly fitted back there.. engine, risers, cab es, and all that.. it's difficult to get in there to see anything.
With one eye I can see the fresh water dripping down from what appears to be the Bell Housing.. but that may just be what it's dripping from and not the source. I went out there today with my camera snooping around and found a crack at the bottom of the OMC 909527A Transom Seal (photo attached) ..
I suppose I'll seal that hole off and dip the boat in the water again to see if it's still leaking or 'found the leak', or is there something else to do to diagnose the leak?
New to Me - 1986 SeaSwirl 18' Bowrider - OMC 4.3L V6 'Stringer' ?
